About to order sprockets, what length chain?
https://sprocketcalculator.com
Use the link to view your chain links needed and gear ratio
First off, please verify these are the correct parts:
From RockyMountain
47 Tooth rear sprocket Part# 1022350066
14T Tooth front sprocket Part # 1021470091 (supposed to fit XR650L as you people say is interchangeable with our bike)
Do I need a 108 length or 110 length chain? I just want to make sure I have the right stuff selected and the correct length chain before I pull the trigger.
From RockyMountain
I did not ride my 06 klx long with stock gearing...I went 13/48 and bought a 120 link green chain...It was plenty.
I set the snail to 5 and let it eat..after a couple of rides adjusted to 9..then a couple days later cut a couple of links off and readjusted.
cheap chains stretch...it does 50mph at 6000rpm. im running a 110/100 trakmaster.
