5000 ft Carb Jetting
Old Aug 29, 2006 | 05:57 AM
gfoster's Avatar
Default 5000 ft Carb Jetting
I have all the mods installed, Muzzy exhaust, N1TC needle, High flow snorkel, K&N Air filter, removed/capped hoses under tank, 13 tooth counter sprocket, drilled out the crankcase exhaust, and carb mods. Tryed a couple of settings on the carb.
1st try:
120 Main
35 stock pilot
2nd clip from top of needle
2.5 turns on the fuel mixture
Started, idled, and had good power.
2nd Try:
125 Main
40 Pilot
Cir clip 3rd down from top on needle
2 turns on fuel mixture
Didn’t see a noticeable difference in power, the bike did not start right away, and the idle was erratic. I liked the 1st try setting better. Definitely running richer, you can wind up the rpm’s let of and no popping at all.
On my third try:
120 Main
35 stock pilot
3nd clip from top of needle
This is where I'm at right now, bike started, idled, and had good power. I can wind it up to 10K rpms with no popping. Anyone have any other settings that they like at this altitude?
Old Aug 29, 2006 | 06:16 AM
Default RE: 5000 ft Carb Jetting
Sounds like you've got it dialed in, g.
SlapDrum
Mar 6, 2009 05:19 PM
monstarv
Ninja 250R
Jul 25, 2008 02:30 PM
Nitrospaz19
Jul 22, 2007 12:40 AM
ZX12Rider
Jul 2, 2006 03:35 AM
hammerbyte
Jan 10, 2006 02:24 AM
