351s gearing and chain
Old Aug 5, 2013 | 05:42 PM
Illking's Avatar
Default 351s gearing and chain
Ill be spending the morning shift of my work reading through all the gearing threads but just wanted to get peoples favorite combos. I snapped my chain tension bolt on one side at big bear last weekend and did a number on my chain and sprockets. Im replacing all. I was just curious what people are really enjoing on bored out s models. Id like to still have legs on the freeway and I commute city streets to work every day, but most interested in ripping on trails. Thanks for your insights guys!
Old Aug 5, 2013 | 06:48 PM
cegusman's Avatar
I just change the counter sprocket depending where I am going to ride. Trails. 13tooth Hwy 15tooth. May pick up another 14 tooth to have an in-between.
Old Aug 5, 2013 | 06:55 PM
Illking's Avatar
I had just been running 15/42 and it seemed pretty good for my riding. I have 13 14 & 15t but havent played with rear sprocket at all
Old Aug 6, 2013 | 01:33 PM
grahamgower's Avatar
I ran a 48/13 combo off road. Was like a tracktor. Totally useless except on really tight stuff becuase from 3rd to 6th all felt the same. Gone back to standard rear and 14 front for all round performance. I have a 13 and 15 depending on my mood. The 331 with Webcams has plenty snap off idle, so I am happily back on stock gearing.
With the SF setup 15/39 is really tall and gives perfect gear ratio on road, but the bitch wont wheely, so 14 front does it for me.
Old Aug 6, 2013 | 02:23 PM
I ran a 49 rear and 13/14/15 up front until 351, then dropped the rear to 45, pulled links from the chain, and still run 13/14/15. I miss the 49 occasionally on the really steep cruddy stuff, but all around I think I can live with the 45.
Old Aug 6, 2013 | 05:02 PM
Illking's Avatar
are there 42 T aluminum sprockets available? im only seeing steel
Old Aug 6, 2013 | 06:02 PM
Why do you want aluminum? More expensive, wears faster, and sure it's a little lighter but is it enough to notice on your KLX?
I saw in Dirt Bike mag recently where they have aluminum sprockets with a steel outer ring so they wear same as chain and not faster than the chain. Cool. And a tad pricey.
Old Aug 6, 2013 | 06:32 PM
ol'klx-er's Avatar
I don't even want aluminum for the front sprockets on my MTB.
Old Aug 6, 2013 | 06:35 PM
Illking's Avatar
thanks for the input guys, i was thinking id save some weight but i guess your right a sprockets not gonna turn my bike into a KTM-husky-beta-berg
Old Aug 6, 2013 | 08:11 PM
Dang. I was hoping you were making one of those husa-beta-berg things.
Steel for the win. Cheap and durable.
IDRIDR
Jul 19, 2017 06:13 PM
Websurfing101
Aug 12, 2015 01:28 AM
carters2
Nov 20, 2009 12:14 PM
768 Ryda
Sep 6, 2007 01:09 AM
brenmotox206
KX65
Apr 8, 2007 03:13 AM
