351 break in
Old Apr 23, 2012 | 02:30 AM
2007 Green Machine's Avatar
Default 351 break in
Well, I should be getting my 351 on monday or tuesday and plan on putting it together next weekend. How did you break yours in? Easy or hard? Any heat cycles while it's still in the garage or just start and go? I know this may be opening a can of worms becasue everyone has their own ideas. I thought I seen somewhere here about the mototune break in, but couldn't find it.
Old Apr 23, 2012 | 03:23 AM
jhoffy22's Avatar
Can of worms is right. I side with those that say to break it in hard. It's what I did to mine and I actually tore mine down within 500 miles of breaking in the new 351 and everything appeared great. You can't ride it like a girl and expect the rings to seat right.
Old Apr 23, 2012 | 03:44 AM
CousinLarry's Avatar
Search, everything you're posting about has been covered many times over the years.
Old Apr 23, 2012 | 07:21 AM
I only post on things I can't find. Maybe I'm not using the right words. If everything has been talked about then this site should just be shut down and only available to searching. If you think I'm wasting your time, then just look past my posts. Thanks.
Old Apr 23, 2012 | 07:51 AM
wildcard's Avatar
Just take it out and run it. Try to get on and off the throttle to load and unload the rings as much as possible. Do this for 10-20 miles and then change your oil and filter.
Done.
Old Apr 23, 2012 | 11:12 AM
I don't think you're wasting my time - I don't give a s#($. I think you're wasting YOUR time asking questions that have threads pages and pages long on the answers you're looking for. You could have had an answer already by searching instead of waiting for someone to decide to type out their experiences again.
I'm going riding.
Old Apr 23, 2012 | 12:40 PM
Blackheart58's Avatar
It's not like you're ridding the transmission gears of scharf...it's just ring-seating. On and off throttle rather vigorously for a few miles and they should be seated just fine. Just don't baby it. Congratulations!
Old Apr 23, 2012 | 12:45 PM
Malves's Avatar
Old Apr 23, 2012 | 12:47 PM
JoelThailand's Avatar
+1 CousinLarry, I found 6 threads this year on break-ins.....
https://www.kawasakiforums.com/forum...-klx250-37268/
Below is cut n pasted from a previous post I wrote, from an older thread.
I have broken in a few bikes in my time & always do a ladies/road version of the Mototune break-in technique. I think the first 100km (70miles) are the most important & like to do three full heat cycles. example three 20mile runs with smooth throttle & keeping revs under 5000rpm then let cool down over night & same again for 3 days. Then change the oil/filter as any metal due to bad tolerances will be in the oil after the third heat cycle.
The next 500km (350miles) i will, once fully warmed up go up & down the rev range like a ****** knickers, slowly & briefly inching my way towards the redline! Never sit on a highway at a set speed for hours just clocking up the miles as this will not seat/bed in the rings properly. This section of the break-in is more like the Mototune method. I'm not running it like i stole it but it's quite energetic compared to a normal break-in......But you can running it like you stole it, if you want after the 1st oil change!!
Old Apr 23, 2012 | 01:39 PM
Pogiboy's Avatar
After reading the above post, then I think I did mine wrong. i went and rode my bike on the trail with lots of high rpm like theres no tomorrow. So far so good hopefully. only time can tell. Btw dropped my bike hard during that ride and scratched her bad.
