Is a 3.0-18 tube to small for the rear?
Old Apr 27, 2015 | 02:26 AM
canehdian_guy's Avatar
Default Is a 3.0-18 tube to small for the rear?
Just realized I was sold a 3.0-18, or a 90-90-18 tube. Is this too small for the rear tire?
Old Apr 27, 2015 | 10:27 AM
doum's Avatar
You can even use the front one in the rear tire when you're stuck.
It should work no problem.
Old Apr 27, 2015 | 03:49 PM
Thanks! I've heard that before.
Although I'm sure this tube will work, are there any potentially negative downfalls to running it?
This is my first tire swap so I want to make sure I get it done right.
Thanks
Old Apr 27, 2015 | 04:26 PM
ol'klx-er's Avatar
Get the right sized tube. A 3.00-18 tube is going to be a bit thin stretched to 4.60-18 tire.
Using a front tube in the back tire is an emergency measure.
Old Apr 27, 2015 | 10:46 PM
Take it back, unless you did it on-line.
Fact is it will stretch and odds are it won't be any big deal considering some tubes range over an inch in fit according to labeling, going from 4.00"-5.10". Like this IRC tube on ebay. A puncture will be a puncture regardless.
cegusman
Jun 15, 2011 06:49 PM
Mr. Toad
Ninja 250R
15
Apr 24, 2006 08:58 PM
Fremont250
Apr 5, 2006 11:15 PM
gotrice
Mar 20, 2006 10:40 PM
gotrice
Jan 21, 2006 11:36 PM
