250S stock carb needle question
Old Apr 26, 2009 | 05:20 PM
RDHJ's Avatar
Default 250S stock carb needle question
is the 2006 needle adjustable? would it be advisable to put in a shim if it isnt?
Old Apr 26, 2009 | 06:48 PM
Xplosivo1's Avatar
Just use some small wahsers. I shim would lean it out, a washer would richen it by lifting the needle. Make sure you have access to the fuel screw though, fine adjustments can be made there.
Old Apr 27, 2009 | 12:06 AM
lcpl0331's Avatar
No they're not adjustable and yes you can shim it. You won't hurt anything by raising the needle a bit.
stro
Apr 12, 2012 10:05 PM
tay675
Sep 10, 2011 01:53 PM
RimBender
Sep 29, 2009 02:12 AM
BentAero
Aug 21, 2007 11:27 PM
a16tony
Oct 27, 2006 04:45 PM
