250s shock charging valve conversion
Old Oct 3, 2018 | 10:04 PM
Tacoma660's Avatar
So the guy im taking my forks and shock to said he can make it feel a whole lot better without the gold valves.....he better be right
Old Oct 3, 2018 | 10:46 PM
riderm14's Avatar
I don't doubt the shock can be made to perform better, I think it's just a matter of tuning to your liking.
The forks on the other hand. The valve looks like it doesn't have the ability to flow enough oil. Maybe if the ports were opened up it could be made to work.
Let us know how it goes.
RM14
Old Oct 4, 2018 | 12:43 AM
It's possible your guy can hit upon the right combination if he's going to drill out the OEM pistons in the forks, but that can be a real crapshoot. Then even if you drill out the piston to flow a proper amount of oil, you have to match the shim stacks to coordinate with them for your application. And then without a fork/shock dyno, you might have to disassemble and reassemble numerous times to hit the right spot. You notice that Brewster tried numerous combinations before he hit an acceptable mark. This is what something like an RT Goldvalve setup really helps with. It does better than just get you in the ballpark. I had to tweak my GV fork stacks once after initial installation, and the shock was spot on.
Old Oct 4, 2018 | 10:01 PM
Tacoma660's Avatar
the guy does mx and woods bike suspension tuning for a living so im gonna take his word. He asked me a bunch of questions and what my issue is, says he can make it better
Old Oct 6, 2018 | 05:04 PM
riderm14's Avatar
I got the schrader valve in last night. Used JB weld for thread locker. Very straight forward, drill, tap, install.
The shock is back on the bike and seems to work like it's supposed to. Weather I like it or not, time will tell.
5 wt shock oil
160psi nitrogen charge.
Minor change to the valve stack. I moved the crossover one position closer to the valve. Might make it a bit softer. We'll see.
I'll start another thread on valving.
RM14
Attached Thumbnails 250s shock charging valve conversion-img_2349%5B1%5D.jpg
Old Oct 6, 2018 | 05:06 PM
riderm14's Avatar
Tacoma660,
Can you post the shock shim stack your guy uses?
Thanks
RM14
Closet
Jan 9, 2017 05:58 AM
Arctra
Sep 15, 2014 08:20 AM
Subseageorge
Mar 21, 2013 01:31 PM
maineack bob
Feb 15, 2009 06:06 PM
Kawi Wawi
Aug 17, 2006 05:18 PM
