250s Dynojet kit!
Sorry, I didn't compare the springs, just noticed that the DJ one was a bit shorter. I guess there are 2 ways to get throttle response- drill out for more vacuum, or use a weaker/shorter spring.
I am very happy with the DJ kit. Bike runs good. Using the 124 jet......don't think I need to jet up to 128 unless I change the pipe/muffler. The 1/2" hole doesn't change the dyanamics much..............
Just got my 300 dj kit last night....
Put it in...Drives better but not $70 worth.....
If I had to do it again Id buy Kawi parts...Jet and needle and save your cash for a few tanks of gas...I ran it with the a/b cover off...Too noisy and sounded like I wasnt going anywhere but actually was...Pulled the snorkle with the 132 jet and is nice...But not $70 nice...Coulda ran the 128 but figured Id want to try the 132 with my pipe..So just did the 132 with HMF and quiet core..
He should have drove it around a little and he would say.....Well worth the price....210lb rider can wheelie in second off motor with a good pull.....Goes up to 60mph in 4th in seconds...
Moron
um, yeah..........right.
Just wanted to go back a little to the DJ 250 kit contents. Since I had (Not installed)the DJ 300 kit, I ordered the DJ spring for the DJ 250 kit and it is just shorter, about 1". So as I indicated in my carb post, I used the spring instead of drilling the slide.
Or does it not matter, we'll still see the same expected power gains?
Yeah I didnt drill the slide I just used the spring that came with my kit,, the only thing I drilled was the plug hiding the A/F screw and I am totally Impressed with my DJ124 with the snorkle removed,,
even though I find it hard to Wheelie but thats just me.. Im just learning the wheelie process anywayzz
