250s Dynojet kit!
On dynojet website there is a jetkit made for the klx250s 2009, will it be OK for a 2007?
RE: 250s Dynojet kit!
they're the same carb, it's the same kit renamed to make you all tingly when you see the "2009 KLX250S" reference next to it.
Kit #2152 not available yet.
Use #2206 instead.
I orderd the 09 kit last friday
the kits are slightly different if you look at what comes in the kit, the 09 comes with a slide spring as well. Can,t remember if the jets were the same
The KLX250s kit is very different than the KLX300 kit. Different needle, different jets, and they confirmed the need for a larger pilot by suggesting 3 turns out on the mixture screw.
ORIGINAL: marc11 The KLX250s kit is very different than the KLX300 kit. Different needle, different jets, and they confirmed the need for a larger pilot by suggesting 3 turns out on the mixture screw. |
They don't drill the slide bigger either. Why?
Their set-up is a bit different then what we can read here, of what most people do! (fuel screw 3 turns, no slide drill...) I did'nt buy the kit, I already bougth the kawa parts, I was just curious to see what mods they were proposing. Don't you think they tested the kit to make our bike more performant?
