2013 Rear wheel replacment.
Old Oct 15, 2015 | 12:30 AM
Courage68's Avatar
Default 2013 Rear wheel replacment.
Cant seem to find anything for a replacement on a 2013 klx250s complete rear wheel assembly.
does anyone have a source or know of another bike's rear wheel that's a direct replacement?
Old Oct 15, 2015 | 11:46 AM
cegusman's Avatar
I have had good luck buying used on ebay. An 09-15 wheel will fit that bike
Old Oct 15, 2015 | 12:56 PM
Courage68's Avatar
thank you , ill keep an eye out on there.
Old Oct 15, 2015 | 04:35 PM
timc63's Avatar
The 2006-07 rear wheel fits also BUT the brake disc is different and the spokes are smaller diameter.
My road tire is mounted on an '07 rear wheel that I use on my '12. The 09+ rear disc bolts right on.
Regarding the spokes, I don't believe the 06-07 wheel had a reputation of being weak, but the 09 received 4mm(?) spokes compared to 3.5mm(?) spokes on the earlier.
TC
Old Oct 15, 2015 | 10:31 PM
Courage68's Avatar
TC
i dont think weaker spokes would be a problem , i just picked up new motoz tractionator endro IT for the rear.
my plan is to have two rears , one with the knobbys for adventuring , and a more tarmac friendly tire for daily driving
Old Oct 16, 2015 | 04:55 AM
timc63's Avatar
Default Front wheel is different
Yep, I run a Pirelli Scorpion Pro up front and am currently using a IRC TR-8 DOT knobby out back as my primary tires, but if I know I'll be doing a lot of street riding, my second set of wheels have the OE dual-purpose tires.
As stated, my rear street wheel is from an 07 with 09+ rotor, if you want a second front you have to run a 09+ front wheel, on your '13, as the speedo drive is different from the earlier, cable-driven speedo.
TC
Old Oct 16, 2015 | 02:48 PM
Fact is the rear hub is same as the KLX300, but as said you will need the bigger 09-later rear rotor or if cost effective, buy an 07-earlier rear caliper carrier and the smaller rear rotor. Bolt hole/thread size may vary too.
I have the smaller rotor on the back of my 09 because it had a KX rotor mounted, I got a 300 rotor, but it was same size, 220mm vs 240 I think. I traded carriers with another rider, because he wanted to run the bigger rotor - I didn't. The small rotor still can easily lock the rear wheel, but should take a bit more effort, aka more control for off road. I guess the thought may be that new riders who may ride the 250 would be more inclined to use the rear brake over the front, so give it a bit more power on the street.
I believe there are a number of KX wheels that would work too, but likely have 19" rims.
Old Nov 9, 2015 | 11:42 PM
timc63's Avatar
Default 07 rotor on 09+
quote clipped....
Hmmm, it is hard to modulate or not lock the rear on dirt...
1) Did you notice much difference with the smaller rotor?
2) Did your original caliper just bolt onto the 07- carrier?
TIA,
TC
Old Nov 10, 2015 | 11:38 AM
doum's Avatar
I'm running the 09 brake on my 07.
I've post some pictures here https://www.kawasakiforums.com/forum...e2/#post517751
Old Nov 10, 2015 | 10:10 PM
TIA,
TC
The smaller 220 rotor would be harder to lock up, less leverage based on rotor size to rim size. I never rode one with the larger rotor, so I have no idea what it is like. I will say even the 220 is stronger than I really like, I don't understand the need for the 240 that was put on in 2009. Maybe okay for the SM version with a wide sticky rear tire or a new rider who ignores the front brake, but I have to really be gentle with the rear brake. When using the front brake like I do it is not unusual, if I'm not careful, to slide the back tire a shade now and again. I've never looked into it, but I may have to see how small a pressure valve might be. I'd love to be able to back it down if possible.
The brake caliper is a bolt on. They used the same caliper, making up for the larger rotor with an appropriate sized carrier. With the large carrier the brake pads were only sweeping about half the rotor. Changing to the smaller 06-07 carrier and now the pads sweep the whole rotor.
