2010 klx250sf turned 351 issues!!!!!!!!!
Old Aug 24, 2012 | 11:17 AM
morrisdp's Avatar
All the work was done by a excellent mechanic,,,im sure he would have caught a bad gasket....He is tryn to get me back on the road at a good price but you can see on the cylinder wall a score mark...Im going to go with a 330 kit or say f##k it and put it back to a 250 sell it and buy a bigger bike still thinking but the amount of money this upgrade is costing and the down time is not worth the hassel...
Old Aug 25, 2012 | 02:10 AM
RimBender's Avatar
" better is often the enemy of good enough"
wB
Old Aug 25, 2012 | 03:09 AM
wB
Dang! Ain't that the truth. Can I use that one?
Old Aug 25, 2012 | 03:59 AM
GaryC's Avatar
I am sorry but a leaking head gasket would not score your cylinder.
something was not done correctly if you have a scored cylinder.
Old Aug 28, 2012 | 10:39 PM
durielk's Avatar
On my install I used ample supply of mating goop, selected at the NAPA dealer for the application. With goop & proper torquing, the thing should not leak.
I agree, for the amount of time you ran the bike, excess water in the cylinder, should not have scored it unless you were running it at max power and max temp. If you were following breakin procedures, the cylinder would never get that hot.
Old Aug 29, 2012 | 09:00 PM
Blackheart58's Avatar
We've used that saying in surgery for decades...so, go ahead and use it!
Old Aug 29, 2012 | 10:19 PM
BigSky KLX's Avatar
Originally Posted by klx4me
^^^This is why I'm reluctant to install a 351 kit; having the water jacket port against the metal compression sealing ring is not an ideal design. I wonder what reliability would be like such as in racing when constant wide open throttle is the norm?
Honestly, Bill Blue has done several hundred 351 kits now and I have only ever heard of 2-3 failing. I think two of those were "installer" errors.
I have 3000 hard miles on mine and it runs fantastic. I know of several other members here who have upwards of 15,000 miles on their 351's with them still going strong.
I have also installed a temp gauge on mine and honestly ripping up the mountain pegged in 3rd and 4th gear while 95 degrees out and the bike runs cooler than my car does.
Old Aug 30, 2012 | 02:47 AM
[QUOTE=klx4me;480717 I wonder what reliability would be like such as in racing when constant wide open throttle is the norm?[/QUOTE]
First off, it isn't a racing bike. That said, I don't hesitate to run mine wide open whenever I like, as long as I like, as hot as the temperature may be.
Old Aug 30, 2012 | 10:32 AM
I have never heard of coolant scoring the cylinder walls. If you got any amount of coolant into the cylinder you would know. Liquids dont compress, they tent to just bend the connecting rod. Unless the leak was a drip here and there. Sounds fishy to me.
Old Aug 30, 2012 | 02:47 PM
stro's Avatar
Default ditto
Ive got a couple thousand kms on mine and have run it hard in hot moab temps wide open for a long time and didnt have any overheating.My fan came on at the same time as my buddies drz, so the wet sleeve thing isnt something to worry to much about me thinks.
