2010 KLX250S carb problems
Old May 14, 2011 | 06:45 PM
Ckahleer's Avatar
There is a down loadable service manual in the sticky thread section of ths forum.
You shouldn't have to play with different float levels, just set it as decribed in the manual.
In the past I have attached a soda bottle with gas in it to the handle bars, put a length of tube in it that would reach the carb, started a syphin and attached to the carb fuel input fitting.
This way you can eliminate the tank, pinched hoses, petcock, as the source of the problem.
Since you have already been in the carb at least 10 times, If the bike is under warranty, consider putting the bike back to stock and take it in for the dealer to fix.
Craig
Old May 15, 2011 | 01:04 AM
mooren's Avatar
Well I am goin to take it to the dealer now but , if I put it back to stock that defeats the purpose of doing the uncorking wich they said was fine and that piping it and jetting it will not void the warranty, so hopefully it goes well and they figure it out but maybe tomorow I'll give er one more shot. I better find this manual where is it ?
Old May 15, 2011 | 02:08 AM
Highbeam's Avatar
Originally Posted by mooren
I even tried goin back to the stock 35 pilot and re-adjusting the float level, still wont run. Really regretting buying this POS and adding over $500 in add ons what a waste !
It's not the bike's fault.....
Old May 15, 2011 | 06:49 PM
mooren's Avatar
Took the carb all apart again and I have the float level set at 17mm to spec and it still does the exact same thing starts and runs with a little surging then all of the sudden gets real rich, but when i turn the fuel off and drain a little fuel outta the bowl it runs fine again ....................
Old May 15, 2011 | 08:05 PM
mooren's Avatar
Tried putting a smaller main jet and stock pilot and lowered the float leve again and still the same thing sounds like its missing and has way too much fuel goin in any prognosis on a carb that runs rich no matter what you do ?
Old May 15, 2011 | 10:37 PM
Ckahleer's Avatar
Attach a clear tube to the drain port on the bottom of the carburator bowl. Route the tube up along side the carburator and open the drain screw. This will show the fuel level inside the carb. If your float and float valve are working properly, the fuel level should remain constant while the bike is idling.
Note: put sonething under the kickstand to get the bike as straight up as possable.
Don't let the tube contact the exhoust pipe. Don't ask me how I know.
Craig
Old May 19, 2011 | 01:33 AM
mooren's Avatar
I have now sent the bike back to the dealership.
There having a tough time too, can't figure out whats making it stumble and just run way to rich at any steady throttle above idle to wide open, Idles fine !
Old May 19, 2011 | 10:23 AM
David R's Avatar
They should be able to fix it in no time.
Its just a one barrel carb.
David
Old May 20, 2011 | 12:56 AM
mooren's Avatar
Lol I think theres a defect in the carb, also may be an electrical problem, either way its going to take a really well assembled mechanic to figure whats wrong with it !
Old Jul 22, 2011 | 04:26 AM
rschopp's Avatar
What was the final out come?
