2009 Klx oil leak
Old Feb 23, 2019 | 11:06 PM
larry556's Avatar
Default 2009 Klx oil leak
I have spotted a small oil leak , its coming from the small
hole under the water pump. Its a very small leak only a drop over night im wondering if it would be an easy fix or not?
Old Feb 24, 2019 | 02:55 AM
GBAUTO's Avatar
There is a set of seals in the R/H side cover behind the water pump. Go to page 4-12 in the service manual-looks like the internal oil seal next to the ball bearing is what's leaking. You have to pull the clutch cover and do some simple hammer/driver work to get the old parts out and the new ones installed.
Old Feb 24, 2019 | 03:36 PM
larry556's Avatar
Will i need to get a water pump rebuild kit for this also? do you know where i can find this specific seal i cant seem to find it in the service manual mine just says replacement parts?
Old Feb 24, 2019 | 05:38 PM
GBAUTO's Avatar
It's listed in the OEM parts fiche under Engine Parts-engine covers. There's a small bearing(shouldn't need that), an oil seal and what's called a mechanical seal. I suspect the oil seal has hardened and is what's dribbling. I would replace both the oil seal and the coolant(mechanical) seal. You will also need a clutch cover gasket and water pump gasket. Search threads for water pump replacement, you'll probably find a photo guide on how to replace the seals.
Old Feb 24, 2019 | 06:19 PM
larry556's Avatar
Thumbs up
Ok i found the seals i need was looking in the wrong section of the parts list, so i should not have to pull the bearing behind the oil seal? ordered both seals and a new gasket for the water pump.
why do i need a clutch cover gasket though? water pump is on the right side of the engine.( I also forgot to mention in the title that i have the SF model and not the S don't know if there's any differences)
Thanks for the speedy replies though the info is much appreciated , with a little more reading i think ill be good to go.
Old Feb 24, 2019 | 06:52 PM
larry556's Avatar
Sorry i jumped the gun i see the clutch cover gasket your talking about now , seeing that i need to take the whole right side cover off to change the oil seal rather than just taking the water pump off?
also can i replace the oil seal without taking the bearing out i dont have a bearing puller or anything to press the new mechanical seal in.
Old Feb 25, 2019 | 02:51 PM
GBAUTO's Avatar
You should be able to use a small punch or drift to tap the bearing out of the cover. Use a socket with approx. the same diameter as the mechanical seal as a driver to install the new seal-tap it in place with a hammer. Use the same drift/punch to remove the seals.
Old Feb 25, 2019 | 04:11 PM
larry556's Avatar
Ok good to know , hoping to get a break it the weather so i can get started on this (went from 50 degrees to 20 yesterday) I just rebuilt the carb a month ago and the bike runs better than ever then i noticed the darn oil leak.
Thanks for the info though bud. Might have other questions if i run into any trouble
travatron4000
ER 6N
Jul 15, 2018 09:32 PM
travatron4000
Ninja 650R
Jul 12, 2018 06:40 PM
pbanx
Jul 21, 2007 04:55 PM
pbanx
Jul 19, 2007 10:32 PM
nucci13
Aug 2, 2006 06:34 AM
