2007 KLX250: Valve clearances/shim replacement.
Old Apr 28, 2011 | 10:22 AM
Masson's Avatar
When taking the lifter off could you use one of those magnet pens? I would think it would take the lifter with the shim so you dont have to worry about dropping it.
Any takers?
Old Apr 28, 2011 | 10:56 AM
Thats what i used to get the bucket off i dont think the magnectic part helped keep the valve shim in though i think just the oil kept it stuck to the bucket.
Old Apr 28, 2011 | 11:02 AM
maninthesea's Avatar
Any takers?
Thats exactly what I did both takeing off and putting back with the magnet end of a telescopeing magnetic pickup tool that fell apart.
Old Apr 28, 2011 | 03:39 PM
ol'klx-er's Avatar
Originally Posted by 2007 Green Machine
I have not checked my valves yet but it looks like a pain in the butt. My 87 mojave 250 is super easy. Once the cam cover is off, you only need a screw driver and wrench to adjust the cam's. I don't understand why kawasaki just didn't stay with the same design. Now the cam's need to come out!
Yes, the newer design is harder to adjust. But: The check interval is much greater and adjustment is less likely to be required. With the shim/bucket system it's basically only the valve/valve seat that are wearing. In the old system most of the wear was at the valve stem/adjuster screw.
Old Apr 29, 2011 | 04:21 AM
2007 Green Machine's Avatar
So, here are a few dumb questions. Maybe this should be a new thread?
1. Where do you buy shim's from? Dealer?
2. Do you buy them single or do you get every one available in a package.
The last thing I want to do is check my valve clearances, and then have to wait for the right ones. If your able to buy an entire selection of them that would be great. I'm still a long way's from checking. My bike only has 1800 miles, and I think the manual says to check at 7500 miles.
Old Apr 29, 2011 | 04:50 AM
Green Machine
I picked up a "Hot Cams" kit off of E-Bay you want the 7.48mm Was less than $100 as I recall. But not much less. You can get single cames from your dealer but you have to be confident they will have them in stock and will be open when you decide what you want. Kit was worth the investment for me considering where I live.
Cheers Jim
Old Apr 29, 2011 | 11:51 AM
Klxrelic's Avatar
Great write up! I will be checking my valves in the near future, this helps me out a lot! Btw how many miles are on your bike?
Almost at 33,000 Kms, so that should work out to just over 20,000 miles.
Old Apr 29, 2011 | 04:12 PM
Masson's Avatar
WOW! Very nice. Any problems that have come up for you in those 20,000? Or just routine maintenance?
I like seeing people with 20,000+ makes me feel my bike will last a very long time
Old Apr 29, 2011 | 04:13 PM
Im at about 10,500 right now.
Old Apr 29, 2011 | 05:16 PM
David R's Avatar
I could use (4) 3.00 shims. Mine are 3.05 and its on the lower limit.
David
