2006 klx250s
Old Jun 13, 2012 | 02:07 PM
KawiHonda's Avatar
Default 2006 klx250s
Hi,
I've been lurking for awhile and this is my first post. I have a 2006 KLX250S, purchased used about one year ago with about 3k miles. I've done some off-roading and short road trips. I have never seen the radiator cooling fan come on. The only thing that I've found in the forums relative to this is that the fan rarerly comes on. However, I want to be certain that that it does function.
Is there a procedure to test the fan and thermostat (or whatever is to switch it on)?
Thanks,
Geoff
Old Jun 13, 2012 | 02:15 PM
Welcome to the forums. Mine only came on one time in 100 degree weather on a single track trail going real slow. If you want to make sure its working just let the bike run in the driveway and pull up a chair, cause it might take a while.
Old Jun 13, 2012 | 02:18 PM
Welcome to the forum. And great selection on you KLX. 2006 - best year and best color!
Ride really slow up a steep climb, first gear, on a hot day.
I've seen the diagnostic testing procedure posted up here a few times before. Maybe someone will re-post, or search around. Did you check here?
https://www.kawasakiforums.com/forum...q-links-30733/
Old Jun 13, 2012 | 03:03 PM
KawiHonda's Avatar
Guys - Thanks for the replies. I definately haven't been riding during 100 degree day yet, but I have done some very long woods trails and single track.
None of my forum searches produced anything but I will look at that link you had sent.
Old Jun 13, 2012 | 04:46 PM
I'm contacting Patrick, the forum search sucks!!! I typed in GPS in the KLX 250 section and got nothing. That ain't right!!!!!
Old Jun 13, 2012 | 05:05 PM
stephenmarklay's Avatar
For whatever reason almost every forum I am a member of 3 letter searches don't fly. Someone smarter than me may know the answer.
You can always do the dumb down search in google as in:
GPS site:KLX 250S - Kawasaki Forums
Old Jun 13, 2012 | 05:15 PM
Yeah well I also typed in Fan not working and still got zip
Old Jun 13, 2012 | 06:03 PM
jhoffy22's Avatar
Here is the best way to search the forum:
1. Go to Google.com
2. Type this into the search box:
site:https://www.kawasakiforums.com/forum/klx-250s-71/ keyword you are searching for here
Type it exactly as above, replacing whatever you are searching for where I have written keyword you are searching for here.
For example,
https://www.google.com/search?sugexp...w=1302&bih=731
Click the above link and you will see what I'm talking about.
Old Jun 13, 2012 | 06:15 PM
CousinLarry's Avatar
Your fan works, carry on.
If it didn't work, and you got to the boiling point, your red temperature warning light would come on even before it got hot enough to damage anything. If red temp light comes on, and fan never did, your fan or fan switch is broken/shorted - shut the motor off.
In short, the bike is fine. Red means danger.
tmpierced
Jan 12, 2007 03:16 PM
tmpierced
Jan 11, 2007 06:29 PM
1iviper
Nov 3, 2006 06:33 PM
Scott V
Nov 1, 2006 06:18 AM
wolv1001
Jul 31, 2006 10:40 PM
