2006 KLX205 instrument illumination Light replacement
Old Jan 2, 2013 | 11:27 PM
ortme's Avatar
Default 2006 KLX205 instrument illumination Light replacement
My, new to me, 2006 KLX250S did not past the Maryland State inspection due to the light that illuminates the instument panel not functioning.
Where is a source for the older KLX250 cluster bulbs ? Did not find any reference on the net. Not sure if it is a bulb or a LED.
Seems the newer klx250 use LED.
Regards,
Glen
Old Jan 3, 2013 | 01:41 AM
ol'klx-er's Avatar
I think it's probably a common bulb. Check out this thread's 10th? picture:
https://www.kawasakiforums.com/forum...dometer-9410/?
Take out a bulb and go to the auto parts store.
Old Jan 3, 2013 | 07:20 PM
MikeW's Avatar
probably whats called a bayonette bulb
and depending on the size you may be able to fit led in there
to easily change the color or get a crisp white
take a pic when you remove it I will let you know what type
ive changed alot of my bikes to led so far they have all been the same
but one also used an even smaller one but I had found the led version of that one too
went with blue led's on this one
stock
and a nice white one on this
no before
and in person looked really white
Attached Thumbnails 2006 KLX205  instrument illumination Light replacement-0915101126.jpg   2006 KLX205  instrument illumination Light replacement-7.jpg
Old Jan 3, 2013 | 09:42 PM
ortme's Avatar
Default I pull the instument bulbs
The tiny bulb has 12 volts 1.7 watts as 12v 1.7V and then a name I can't read coming out of an oilwell derrick picture something "Josh.....iog"
I think it is called a "capless intrument bulb". So, I am off to an autoparts store to find a match.
Thanks for the ideas.
Glen in Olney, MD
Old Jun 11, 2018 | 03:09 AM
drm's Avatar
drm
fyi, bulb number 2721 is what you need for the 2006-2007 instrument cluster lighting. found them at local auto parts store.
resurrected my instrument cluster after a fall last year. tach glass broke along with 3 instrument lights burned out. replaced the tach glass with thin plexiglass found at the local hardware store.
good as new.
Kaw'ee
Jan 14, 2019 02:28 AM
skelator
Apr 22, 2014 03:28 PM
Ckahleer
Jun 29, 2012 04:11 AM
markmeinteil
Oct 24, 2006 10:31 AM
S4ONE
Ninja 250R
Jan 5, 2006 08:19 AM
