2005 KTM EXC or not?
You will appreciate that rekluse I would bet!
I have an 05 525, it's the SMR, which has the SX motor in it. And mine is pretty dang high strung compared to the KLX. I can wheelie no problems and no talent in 5th gear, going about 80-90kms. You will also appreciate the wide ratio, 6th gear will just cruise along compared to the KLX. 1st and 2nd will be a bit faster on the EXC, compared to the KLX but the rekluse will help you get used to that. It might be a bit overwhelming the amount of torque at first, as I was VERY overwhelmed with the extra power I had to deal with. Now I'm used to it and feel I'm ready for a performance upgrade.. which is cool, because this thing is nuts and it's STOCK!
Love my KTM, you will not be unhappy I'm sure of it!
Just so you know, if it's an 04/05 model, if it's the SX, or SMR, they had valve guide/valve issues, but if it's the EXC, you're good to go. Oh, and valve clearance checks are a sinch once you do it a couple times! 2 little covers on top of the cam cover, take em off with 3 bolts each, a flat head screwdriver and a wrench will adjust them and you don't even need a feeler guage with the 1/6th turn method.
I have looked at the Suzuki's for a long time. I opted for the KLX-250S for 6th gear and lighter weight at the time.
I could add a Bill Blue 351cc topend and a pumper carb for less then $800 so that is a more appealing (and a cheaper) option for me. Also, the 400cc motor isn't that much more then a modified KLX-250S so, I think my money is better spent on a better motorcycle.
I really want better suspension in addition to the better motor so, I'm looking at Husky's, 'bergs, and KTM's.
It sounds like you have outgrown the KLX. Not a bad thing, just means you can handle something meaner. Some of us older guys will never outgrow the little KLX but we'll get passed by alot of riders on the trails, sand etc... I want a KTM real bad and I know it'll take years for me to ride it as well as my Little KLX. Get the KTM if you got the cash. I bet you'll be in heaven if you get it!
