2002 kx250 springs
2002 kx250 springs
Would they be a stiffer replacement for the 2009 KLX? Will they fit?
Craigslist ad
factory connection fork springs pn lsb-048 .48kg rating(sells for 100 take 50)
factory connection rear spring aln-0056/5.6kg spring rating(sells for100,take 50)
Craigslist ad
The fronts springs won't work. Ours are 43mm and KX250 is 48mm diameter. The rear is the right diameter, but the spring rate (5.6) is the same as the stock KLX250S.
