19" KX rear wheel fitment
Guest
Posts: n/a
I'm just wondering if the 19" rear wheel used on KX's since '89 would fit on a KLX? I like the look of the larger wheel and also the rear rotor will then match the front as far as how they're drilled out. Also, what about the rear rotor guard that hangs off the bottom of the swingarm. Does anyone know where to get one of these? Thanks, Travis
Just a word of caution, by going to a 19" rim you would loose a lot if not all selection of DOT approved dual sport tires on the market. Not a biggie if most of your time is spent offroad.
I just wanted to make sure you had thought of that.
No, there are some 19" DOT tires out there (I found that Maxxis has them) but you selection of brands and tread designs is smaller because the 18" rims are more popular on DS bikes then 19" rims.
