18,000 Mile valve adjustment.
Old Sep 27, 2012 | 11:13 PM
ShadetreeAZ's Avatar
Cool
Hey thanks for all the great guidance on the resources and all. I'm just coming up on 3500 miles in a little more than 6months, so I've got a little time to study up and get prepared to do this. I live in an area that has a lot of year round riding weather so I'll be riding alot through most of the winter months. Anyway I appreciate your help.
Old Sep 28, 2012 | 11:03 AM
Originally Posted by ahnh666
the hardest part is just getting the valve cover off...very little space!...you have to just start removing stuff out of the way...i think it works best to lift and slide out to the left....gas tank, peacock and cansister all needed to come off...and, i had to remove the right fan also...after that...it's all smooth sailing from there....
You have to take the fan off? All i have to take off is the gas tank.
Old Sep 28, 2012 | 01:59 PM
ol'klx-er's Avatar
I had to unbolt the fan and move it up (still against the rad). Even then it was tight getting the valve cover out the left side. Must be a few microns clearance differences between bikes.
Old Sep 28, 2012 | 02:09 PM
I wonder if it's a model-year difference? Didn't need to move my fan on '06.
Old Sep 28, 2012 | 02:21 PM
Originally Posted by Beardoge
Shadetree
The easiest way to convert metric to english is
english times 25.4 equals metric
metric divided by 25.4 equals english
so .05 MM divided by 25.4 equals .002 of an inch
or say I need to move my valves .004 of an inch so
.004 X 25.4 equals .1 MM so figure out what shim you start with then just subtract the difference.
So if your starting shim is 2.90 MM and you need to move your valves .004
2.90MM / 25.4 = .114 thickness and you need to drop .004 down to .110 then
.110 x 25.4 = 2.794 or a 2.80 shim....
I was told that there would be no math....
Old Sep 28, 2012 | 02:23 PM
The right fan? As opposed to the left one?
Old Sep 28, 2012 | 02:25 PM
The second video has no sound..... Whiskey-Tango-Foxtrot!
Old Sep 28, 2012 | 03:15 PM
ahnh666's Avatar
there was no way for me get the valve cover up and over the cam/cam chain on the right...the right fan had to come off to get the cover up high enough...
2009 klx250sf
Old Sep 28, 2012 | 04:16 PM
rgoers's Avatar
Ah... SF. Is there a big difference between the S and SF frames?
Old Sep 28, 2012 | 04:22 PM
ahnh666's Avatar
identical...i did the valve check and adjustment on another guy i met online...and he was on a klx250s....
