13 tooth sprocket
Old Jan 13, 2007 | 08:49 AM
Gomerpile's Avatar
Default 13 tooth sprocket
This is a stupid question. I just got my sprocket in the mail. I am guessing that I need to fold down the washer around the nut that holds in the existing sprocket, loosen the bolt, pull out the old sprocket, and do the reverse for installation. Am I right? (I am about to starttearing it apart)
Old Jan 13, 2007 | 08:53 AM
Default RE: 13 tooth sprocket
Yes take a large screwdriver and tap it back straight. Then take a 1/2 inch rachet with a cheater pipe and then get someone to sit on the bike with it in first gear and the rear brake on. It should come off. Does the new sprocket have a shoulder on it?
Old Jan 13, 2007 | 09:12 AM
Gomerpile's Avatar
I have a picture of the new one, but I cant get it to work using the picture button (it is telling me I need a web address for the link.) anyway, if you mean the rubber thing around the stock sprocket, then no. The new oneis all metal.
[IMG]local://upfiles/4019/FC8BF84E70B54D179890AFA9CE0A1DE1.jpg[/IMG]
Old Jan 13, 2007 | 09:21 AM
Gomerpile's Avatar
do you know what size socket that is? I need a larger socket
Old Jan 13, 2007 | 06:28 PM
KAWASAKIspeed's Avatar
ORIGINAL: Gomerpile
Gomer pile you can get a photo site account like photobucket.com and then you use the url from thier site and then you put that into the photo button in kawasaki forums.
good luck.
Old Jan 13, 2007 | 08:20 PM
ORIGINAL: Gomerpile
Sorry I didn't get back to you last night, it got late. Anyway I walked out in the garage, bare feet, ice cold concrete and took off the sprocket cover and found out what the socket size was. Its a 27 mm. I also bought a 30 mm and now I can't remember why.
Old Jan 13, 2007 | 08:29 PM
Did you get anything done on the sprocket change? That sprocket looks like its close to the right one.
Old Jan 13, 2007 | 09:23 PM
hahaha, deej. The 30mm for the stem nut?
Old Jan 13, 2007 | 09:30 PM
Ahhhh yes, thank you I was racking my brain trying to remember why I bought that 30 mm. After all I did grease the steering bearings a few months ago. It must be the old age setting in.
Old Jan 13, 2007 | 09:35 PM
Gomerpile's Avatar
I am going to buy the 27mm today. I live alone, so I think I will run a strap around the rear break and crank it on the frame to stop the back wheel from turning.
