12 volt output to power accessories
Old Sep 13, 2011 | 05:10 AM
  #51
BillMoore's Avatar
It takes about 30 seconds to air the front tire from 14 to 22 psi, and maybe 50 seconds for the back tire. I just leave the motor running at idle, and haven't noticed any effect on the battery.
If that compressor draws 8 amps under load, it would take about 45 minutes to fully drain a 6AH Motorcycle battery, and that is with the motor off...
Old Sep 13, 2011 | 05:26 AM
  #52
go cytocis's Avatar
If you're just going to let the engine idle, I wouldn't even bother. I don't believe it starts spinning the alternator fast enough to generate significant juice until you're at 3 - 4000 rpm (?).
Old Sep 13, 2011 | 03:27 PM
  #53
ol'klx-er's Avatar
Agreed. ^^^^^
Old Sep 14, 2011 | 05:40 AM
  #54
BillMoore's Avatar
True, but when you are done you won't have the extra current draw of re-starting the engine.
Old Sep 14, 2011 | 02:50 PM
  #55
Originally Posted by Matasickle
Awesome.. what did you use to wire it?
(gauge of wire, fuse, etc?)
As you can see I'm pretty clueless..
I got a piece of red and black #14 stranded and wired it right to the battery with a 20 amp flat fuse and holder in line on the positive lead.
Here is the flat blade fuse holder.
FJRTech.com - Dedicated to the FJR1300 Enthusiast!
WestOzKLX
Nov 12, 2009 01:37 PM
je2000
Oct 15, 2008 12:19 AM
Bdbarringer
Sep 21, 2007 09:27 PM
markmeinteil
Apr 13, 2007 08:42 AM
pdrury
Jan 7, 2006 09:26 AM
