12 T front sprocket
Old 03-22-2007, 03:52 AM
Default RE: 12 T front sprocket
Hey who you calling noob? I was the first one to post in this section, in fact I asked Patrick for the section way back when. Now I may be lazy, but I am no noob. Besides that section needs updated as people on here find other stuff.[8D]
Old 03-22-2007, 03:53 AM
Oh and I invented the Internet[8D]
Old 03-22-2007, 03:58 AM
JB1's Avatar
JB1
JB1 is offline
ORIGINAL: deej
You realize your not helping your case any [sm=icon_stickpoke.gif][sm=happy046.gif]
Old 03-22-2007, 04:03 AM
Thunderchild's Avatar
FWIW, I'm running the Daystar. Installed and works fine. No spacer needed.
Old 03-22-2007, 04:26 AM
ORIGINAL: JB1
ORIGINAL: deej
Yea I know.......[sm=sigh.gif][sm=funnypostabove.gif]
Old 03-22-2007, 04:44 AM
Am I the only one who likes the stock 14:42 gearing? I honestly don't think I'd mind going 15:42 or maybe 14:39. The main thing I don't like about going up in the back or down in the front is that it makes the cruising RPMs higher and after a while that tends to wear me out a lot faster on the road. And I never had any problems with first gear being too fast off-road. I guess I'm just different. I reckon I've always been on the fringes of the bell curve, so this should be no different.
While the gearing ratios have no correspondance with the KLX, I got my 49 tooth rear for the KTM and that lets me use the stock chain with the 14 tooth front. My first gearing try was 13:52 and that was a little buzzy at highway speeds. Not bad, probably about like the KLX in 6th gear using stock 14:42. But I tested out 14:49 this evening and I think this gearing is superb. On the high end it would be equivalent to a 7th gear in the KLX, cruising at 60 MPH at around 5000 RPM, just rumbling along is great, I could do that all day and not get tired. Makes first a little high, but with the larger low-end torque, it still lugs along just fine in first so I don't think I'll have any problems going slow when I need to. I tested it a little off-road and it was fine.
Old 03-22-2007, 06:05 AM
Kawi Wawi's Avatar
I'm with you Brian. I wouldn't gear down for anything... Power up! Don't gear down!
Yeah, I still haven't got my big bore kit on yet... Real soon though.
  #30
Old 03-22-2007, 02:45 PM
markturbo's Avatar
I don't remember the brand name of mine, I just ordered a 13 tooth for the Honda 650L and it had the shoulder on it and fit perfect, no increased chain noise or wear.
If they had a 12 tooth I'd buy one just to try it out, even if you don't like it it's not a lot of money compared to a rear sprocket and new chain.
Quick Reply: 12 T front sprocket
