12 T front sprocket
Old 03-21-2007, 08:14 PM
ol guy's Avatar
Location: Kennewick Washington, in the washington desert
Default RE: 12 T front sprocket
A 12 tooth will turn the chain pretty tight. Also it will make the chain run tighter on the deflectors that protect the swing arm. With extra wear and tear on all the parts in the long run i'll bet it's cheaper to go with the larger rear sprocket.
Old 03-21-2007, 08:22 PM
johnnyz62's Avatar
I just received a 48 tooth rear sprocket and 110 link chain from Rocky Mountain ATV. I went with Primary Drive brand components because they were out of Renthal 48t sprockets and o-ring 110 link chains. Also wasn't sure if I would like the gearing so the cheaper components made sense. Together they were a $75 shipped. Probably won't have time to get them installed until this weekend, but hopefully will work out ok.
Old 03-22-2007, 12:47 AM
klxCouple's Avatar
I like these
[IMG]local://upfiles/2315/2B054D0C6BE4444D9F2B4950CF691F0D.jpg[/IMG]
Old 03-22-2007, 12:58 AM
onestarr99's Avatar
Iowaguy Is right the KLX 300 front sprocket wont fit!! This is what I put on.
AFAM sprocket
Part # 24502 13tooth 520 pitch
Phone # 1-800-290-9040
It says it is for a EX/KLR 250-650cc 1987-96 But it is a direct bolt on..I did not need a spacer! I didn't notice any more noise than the stock one. If you have your hart set on a 12 tooth than maybe you can use this info to get a 12t instead of 13t. Good luck and lets us know how you make out...
Old 03-22-2007, 02:30 AM
Hey Iowa, yea I really think the 13 tooth is the best mod for instant and inexpensive power. Hey speaking of the 13 tooth, do you have a brand, model # for a 13 tooth with the shoulder built in that fits our bike, I really want to get that spacer out of there. Its probably pretty rusty buy now, since it was machined.
Old 03-22-2007, 03:35 AM
kawiridr04's Avatar
so if the klx 300 front sprocket doesn't fit what about the rear if i wanted the 48 tooth
Old 03-22-2007, 03:42 AM
Richt's Avatar
I think S Dunne ran a 12 tooth when racing, look at the early 2006 posts under his name .
Old 03-22-2007, 03:43 AM
JB1's Avatar
JB1
JB1 is offline
ORIGINAL: deej
You newbies really need to learn how to use the search...lmfao
https://www.kawasakiforums.com/m_32788/tm.htm
ORIGINAL: YYY.Guy
Anyway, here's the list of sprockets and part numbers that I've compiled:
JT Sprockets: JTF516-13
Sprocket Specialists: 514XK-13
Sunstar: 34113
Kimpex: 101006
The Kimpex has the shoulder built in, so no spacer is needed. Didn't notice any increase in chain noise, either. The only thing that would have made the whole experience better was if it was easier to loosen the dam nut to get the sprocket off!!! (Yes, I did unbend the retaining washer beforehand ... it was still a bitch to get off!)
Hope this helps!
Mike
Quick Reply: 12 T front sprocket
