09 Rear Fender?
Old Jun 23, 2008 | 07:08 PM
75vette's Avatar
Default 09 Rear Fender?
Ok guys I need some ideas on what lines to cut the 09 fender. I have been dealing with it butI think it is time for it to go [>:]. Any ideas or pictures would be great.Thanks for the help
Old Jun 23, 2008 | 08:47 PM
09KLXowner's Avatar
Banned
Default RE: 09 Rear Fender?
there's a sweet line if you can see it. leave just enough off to bolt the plate right below the taillight. the line is so obvious, I'm surprised no one has seen it. from what I've seen, people are just hacking it off straight across, looks dumb imo. personally, I feel they put it on for a reason as a huge mudflap to block mud. personally I am kind of used to it. until I see someone cut where I'm talking I won't do it.
Old Jun 23, 2008 | 09:20 PM
75vette's Avatar
I will look tonight to see ifI can see what you are talking about if not can you maybe show a pic with tape where the cuts should be soI can see?
Old Jun 25, 2008 | 02:02 AM
f1rocco's Avatar
ORIGINAL: 09KLXowner
Im with ya on this 1 @ 100%....I thought if anything I might cut it longer and taper it up to flare it a tad....Maybe use that line they have as my bend point for the 3/4" to a 1" flare....Maybe angle cut the outer edge...But fornow I cant see therear fender while Im driving.....So I dont think about it...
F1
Old Jun 26, 2008 | 12:37 AM
f1rocco's Avatar
I couldnt help myself.....
I used a dremmel and hacked off the bottom reflector tab....Also what was cool is I rotated the license plate bracket and moved the plate up 3/4 of an inch....
I was gonna cut more....But If I didnt like it I was stuck with it...Little@Atime
Old Jun 26, 2008 | 06:08 AM
09KLXowner's Avatar
Banned
that's what I'm talking about. I don't like how that looks and I sure wouldn't do it to my '09. the line starts right up by the taillight and it flows downward, it is an actual line in the plastic too. it leads to an area that can just be cut straight across so as to mount the plate directly to the plastic that is left below the taillight. a hacksaw won't cut it like I'm talking as this isn't your father's plastic anymore- it's pretty tough stuff. it will take a dremel and a sharp blade along with a smooth operator. Like someone mentioned, I can't see the fender while riding and I've seen the mud it has trapped. If anything, cutting the steel reflector mounts off the plate holder will clean alot up. as it stands now, I am going to leave the fender alone. I removed the DRZSM's, but it was just ridiculous. this one, while large too, doesn't seem to bother me as much.[&o]
Old Jun 26, 2008 | 02:10 PM
Hey IG you need to update your avatar
Old Jun 26, 2008 | 03:37 PM
09KLXowner's Avatar
Banned
sorry, the line starts up by the turn signal after seeing the picture above. it's like kawi put it there as a perforated line for this mod.
my '06 deej, is missed and I like that picture as well as that day, it was a good day nearly two years ago actually that pic was taken.
plus, I like to throw people off that don't know me or know that I had an '06 too.[:-]
Old Jun 27, 2008 | 01:35 AM
PeteNFla's Avatar
I used my electric jigsaw with a fine tooth blade, and finished it off with the small sandpaper wheel on my dremel tool, ...you know, to take off those stringy plastic left-overs.
I took off my license plate bracket, eyed up about where I wanted to cut, used a 12" ruler as a straight edge, drew a line with my "white-out" pen, and then attacked with my jigsaw, finishing touches with the dremel.
Mine looks as if it was designed that way. I cut mine about an inch lower than the license plate bracket bolt holes in the fender. It really makes a big difference for the bike's looks.[8D]
Old Jun 27, 2008 | 04:21 AM
75vette's Avatar
[sm=ttiwwp.gif],You have my intrest
vurtle
Jun 9, 2007 04:02 AM
GreenKLX
Dec 13, 2006 09:20 PM
EMS_0525
Jul 3, 2006 06:17 PM
Nobrakes
Apr 28, 2006 07:58 AM
tennisman
Feb 26, 2006 07:05 AM
