09 KLX250s Clunk when letting out clutch.
Old Jan 19, 2015 | 04:57 PM
RockabillSlapMatt's Avatar
I have barnett springs and dirt racer clutch on my 351 klx, the clunk has always been there even before the upgrade, clutch basket looked good to me. I've always assume it's been a drive chain issue, perhaps the feeling of the chains initial friction on the sliders, depending on what gearing you are running.
Old Jan 19, 2015 | 11:26 PM
Chay's Avatar
Originally Posted by 4vman1
No, the basket isn't hard to replace until you look at how much a new oem one costs. How you would check it is by taking out all the plates, and feeling the inside of the baskets fingers. Over time they can become grooved and this affects clutch action. Come to think of it, I don't think that would cause any kind of "thunk" when you let the clutch out. Does your clutch slip on it's own at all? Another thing I thought of, how loose is your drive chain. Even though first seem real low to me, the little klx sounds like it struggles to take off sometimes and sounds like I get a little chain slap.
The clutch doesnt feel like it is slipping, it doesnt quite grab as well as it used to, but i have never had the bike lose power, and spike on the revs. As for chain tension, I am not very knowledgeable on adjusting the chain. I've got an old timer that I ride with that was with me when we adjusted the chain last. What is the easiest way to correctly tension the chain?
Old Jan 20, 2015 | 03:07 AM
durielk's Avatar
Check the manual to adj your chain. Many bikes are different due to exact connection locations.
Old Jan 20, 2015 | 05:26 AM
Chay's Avatar
Right... the manual. I have one of those. * searches for manual *
Old Jan 20, 2015 | 12:34 PM
4vman1's Avatar
The danger of an over tightened chain is that when your rear suspension is compressed about 2/3 through it's travel is when your chain gets it's tightest. The absolute best way to check is to remove your shock and adjust the chain so you can rotate your swingarm up through the motion. Not practical at all unless you were doing other maintenance, so I check at the back bottom of the plastic chain protector that is mounted to the front of the swingarm. Push the chain up and it should come to about 10mm from the swingarm. Then compress the rear suspension and make sure it doesn't get super tight and then you're good. I don't have a manual, but this is the basic way with all bikes, unless of course you own an ATK 406.
Old Jan 21, 2015 | 01:01 AM
I always adjusted mine to touch the screw at the bottom of the swingarm chain slider, I'd rather be slightly too loose than too tight
neonarc
Feb 13, 2015 12:21 AM
dan151
May 13, 2012 12:33 AM
johnnyzx750
Jun 12, 2009 08:33 AM
joe sprocket
Jul 21, 2007 01:08 PM
Bujin2000
Sep 9, 2006 08:05 AM
