09 KLX250S (Aus) - Want to convert to moto
MaverickAUS,
Gday, Rocky and Yeppoon are not to bad, been a bit hot of late .... But you get that.
Lucky the beer is cold.
KLX07OZ-1, et al
Yeah, a set of moto rims for the round town and occasional long trip up and down the coast,
is what i am after,with the option of putting the stock wheels back on for the trips for
running around the bush. And by the sounds using a Trail Tech Vapor means the difference
in circumference is fixed by the push of a button or two.
ddt1972, thanks for the info as well, much appreciated.
MotoFan
KLX07OZ-1, et al
MotoFan
I'd say if you want a set of sm rims (17's) on your bike. and you have the 09' i would just order the speedo from the SF version as its already calibrated to 17" rims. And I would assume its cheaper than a vapor setup
The vapor would be the best option when it came time to swap back to dirt though, only a button push away. I got my Vapor setup for less than $120. Not sure what the factory unit goes for new, but they go used for about $100 here in Japan.
I wouldn't assume that
MotoFan
Sep 21, 2009 08:10 PM
Finger Mullet
May 2, 2008 01:11 AM
