09 Death wobble @65mph-N-850 miles
Old Jul 16, 2008 | 03:41 AM
cliffsta's Avatar
Default RE: 09 Death wobble @65mph-N-850 miles
Mine holds fine at 65 miles an hour (fastest i've ever dared push it). I have 19 pounds in each tire cold (A bit low, but the ambient temps are so high now, I know I gain a couple PSI mid-ride). I'm no expert but I'd think the 30 pounds is playing a factor. Maybe try dropping five pounds and see if that stables it out?
Old Jul 16, 2008 | 03:55 AM
lcpl0331's Avatar
30 .lbs is a bit high. you need the tire to flex some. are you running the stock tires? at 65 mph the bike should be running true. try dropping your pressures down to 20 or so and see how the bike rides.
Old Jul 16, 2008 | 05:10 AM
ORIGINAL: f1rocco
30# of air 200# rider...Slight death wobble at 65 mph plus....850 miles total on the 09....Bike has been grounded before I am grounded....
Next week the cowls and fender get yanked....I wanna see the difference in mpg and drag and handling....
NE1eLse....
lol....try running with the factory spec air pressure first. Damn we get some live ones over here now.
Old Jul 16, 2008 | 01:57 PM
Kawi Wawi's Avatar
ORIGINAL: f1rocco
Its not that bad...A newb would still drive...But not me...I havent gone down and will contnue to try not.....Signed the ungeared 1...
I have to disagree... A n00b would be scared of the wobbles... A seasoned rider would know that this kind of **** happens when you ride a dirt bike on the highway.
Me... I just ride through em. No big deal, happens all the time... I call it more of an oscillation, and I believe it's due to the cross winds catching the front fender.
Just pull your weight back on the seat, loosen up a bit, and relax. You're not going to crash.
Old Jul 16, 2008 | 03:29 PM
WD~40's Avatar
My 09 came with Dun 605's, i run 24psi front and back for the most part. i am 6' #210 and have had no speed wobbles. i have noticed that wind is a huge factor on the KLX being a big guy! when riding a fast pavement leg i ride with my weight more forward, front of seat with legs / knees gripping tank, back bent, head up for aerodynamics.
Be safe!
WD
Old Jul 16, 2008 | 07:34 PM
ZX1100F1's Avatar
21" front wheels are kind of notorious for this, above are some good suggestions also try apllying pressure forward on the bars, A balanced IRC GP110 tire cured it for me.
Old Jul 17, 2008 | 01:37 AM
gerrynolan's Avatar
I experienced the Wobbles bad on my '07. Once I realized sliding back fixes it, I will got up to 85 registered on speedo with no fear. I still have the front wheel on at 2000+ Miles. The rear is a Kenda 270. Sweet tire in my opinion. I love this bike.
Old Jul 17, 2008 | 11:09 PM
f1rocco's Avatar
I turned the rear coil upper valve 2 clicks clockwise and no more wobble....Hmmm....That was simple....I wouldnt have thought two clicks fix it...
Old Jul 22, 2008 | 12:47 PM
Kirkland Jeff's Avatar
I think most wobble is from geometry. If the front end is compressed down, the rake and trail decrease making the bike vulnerable to crosswinds and buffeting from other traffic. Shifting your weight back lets the fork ride high in it's travel, making the bike more stable. I routinely ride at terminal velocity (85-100 indicated) and have no problems with stock tires at 30psi for street. Stiffer fork springs will help, but getting your *** back when tucked in will stop overloading the front end.
09klx250t9f
May 6, 2008 02:32 AM
poodlenuts
Jan 12, 2008 07:54 PM
Rickster
Dec 3, 2007 10:47 PM
biglg7
Feb 9, 2007 06:18 AM
ZX12Rider
Sep 7, 2006 08:39 AM
