07 klx fan not working
Old Sep 10, 2012 | 07:03 PM
toyotabuilder's Avatar
ridden throught the desert in 110-120deg and was hualing *** never once has it come on this bike runs cool, try hooking the fan to 12 volt to see if it spins up
Old Sep 10, 2012 | 08:01 PM
I checked the circuitry per post #4. Fan, relay, and fuse all good. The fan switch is bad per the diagnostics described. When I rode hard through the desert on hot days, the fan never came on because there's enough airflow through the radiator to not need the fan. But when I'm climbing 20%+ grades in 1st gear at less than 5 mph for over a mile through loose shale on a hot day, the fan (used to) come on.
Old Sep 11, 2012 | 12:07 PM
djchan's Avatar
My fan (07 model) has never come on that I know of - even on steep, rocky, slow stuff. Course I'm in a cooler climate as well - Maine, so I always thought it was that. Looks like others have the same experience even in warmer climes.
Old Sep 11, 2012 | 01:53 PM
Yes, this bike's fan doesn't run much, but mines been on many times last year so I know when it should turn on. I could watch the Vapor computer and see it coming. Has your bike boiled over? I got to think the fan should come on before it boils over, unless perhaps the radiator cap is shot.
Old Sep 11, 2012 | 03:10 PM
Yeah, Scott, this is one of the things I really like about the Vapor. That coolant temp sensor really keeps you informed about how the engine temp is going. My fan came on 2 or 3 times this last Colorado trip, and that was because of the gearing and bigger tire issue we talked about on another thread. The 2 years before it never came on with the shorter tire. That bigger tire deal made just that little bit of difference with my 14/47 gearing. I don't think it would have come on this trip with my current 13/47. I just realized that I'm just about equal to stock on the KLX300's OEM 14/50 gearing.
Old Sep 11, 2012 | 05:30 PM
My fan came on a number of times while we were doing Moab last year, but yours never did? Interesting. It surprised me that it would come on going down hill at a slow pace on those hot afternoons. I may replace the rad cap too, but I must think the switch is questionable after finding it testing the way it did.
Old Sep 11, 2012 | 07:56 PM
Pogiboy's Avatar
Originally Posted by teamgreenrider91
ive had the bike for a few weeks now and at first i figured i just hadnt gotten it hot enough for it to come on. but after 90* weekend of riding trails i know it was more than hot enough but my fan hasnt come on once. just wondering if theres a fuse or something to look for that could had blown or what steps i should take to figure this out.
any help would be greatly appreciated
Try to run your ride on neutral fit like 5 minutes with occasional throttle that should turn it on in no time.
Old Sep 11, 2012 | 11:25 PM
Unless its 100 degrees out and you are riding in first gear uphill on a single track trail, it probably never will come on. Mine only came on once under those conditions. After 15,000 miles I figure its the norm.
Old Sep 12, 2012 | 01:28 AM
RimBender's Avatar
One of the wires is very poorly grounded to the radiator under the right side radiator shroud. Scrape the paint shiny and tighten that fastener,
CousinLarry
Sep 6, 2022 01:49 PM
Brad Brown
Feb 7, 2014 04:03 PM
Djsky
May 25, 2012 02:11 AM
KFX Rida
Jun 4, 2009 04:54 AM
tcmotoq
Ninja ZX-7R
Jul 5, 2008 06:24 AM
