'07 Fork Guards?
Old Jul 28, 2013 | 12:10 AM
gearsoup's Avatar
Default '07 Fork Guards?
So, the OEM white ones have gotten quite brittle and didn't take much abuse before falling into many little pieces. Looking on BikeBandit, it appears that my only option is another OEM set, at $30 a SIDE. I've looked around the net to see if anyone makes one, but it doesn't appear that is the case. I've read on here about the possibility of other models/model year fork sliders fitting, but there seems to be some disagreement about what I need to buy and/or modify. Anyone?
Old Jul 28, 2013 | 06:37 PM
The OEM units are junk, and they're horribly overpriced. You need a set of UFO guards that are for a KX...can't remember which model. Maybe you can see the part # in my pic here. You have to drill a hole for one of the mounting bolts, but that's extremely easy since they're plastic. dan888 has a good tutorial floating around here somewhere. They're basically a straight bolt-on deal for the most part. They're made out of what appears to be fender grade plastic, so they're nearly indestructible...and relatively cheap.
Old Jul 29, 2013 | 12:55 AM
Rooster's Avatar
Check out his thread. It has all the info you should need.
https://www.kawasakiforums.com/forum...cements-31419/
Old Jul 29, 2013 | 01:02 AM
gearsoup's Avatar
Quite right, that was all I need. Thanks a lot guys!
Old Jul 29, 2013 | 12:06 PM
JaMan's Avatar
I just installed a pair of black 1995 KX250 fork guards on my 06 KLX250S with minimal modification required.
Old Jul 29, 2013 | 12:21 PM
Best part. They come in black! I have the black ones on my bike.
Old Jul 29, 2013 | 11:11 PM
They hold up waaaaaayyyy better than the stockers. I actually have replaced, my replacement guards, but only because they were pretty scuffed up. When they are only ~$20 you can do that.
Dan
Old Jul 30, 2013 | 12:05 AM
Dan
I'm not surprised you had to replace yours, dan. You're like Mr Magoo...stumbling around...running into things...breaking stuff.
Old Jul 30, 2013 | 03:25 AM
Mr who? Wasn't that the first cartoon ever?
Old Jul 30, 2013 | 11:24 PM
gearsoup's Avatar
Looking at the Parts Unlimited online catalog, the '94-'95 KX250 only comes in white. The '96-'03 comes in white and black. Is this what you have EMS?
(I'd much rather see black on my bike)
UFO online catalog agrees with the above statement
