06 shocks
The stock nitrogen pressure is about 150 psi. The "how" to fill it involves a high pressure nitrogen bottle with a filler hose, closeable fitting, and guage. Just take it to decent motorcycle shop that has the bottle. It's usually an inexpensive service from most shops. You can use air instead of nitrogen. It's not as stable in different temps and air is not as "dry" as nitrogen. The shock piggyback and bladder like a dry environment.
Question: Why do you need to add nitrogen? Did you release what was in there or do you just think it's low? If you didn't release the pressure but feel that it's low, it may be a good time for some shock maintenance........disassembly, clean, and fresh fluid. Maybe even revalve it.
Ride on
Brewster
Ride on
Brewster
If you are like me and weigh around 200lbs, than that is kinda of normal on the KLX. Kawasaki built the KLX towards lighter folks. A heavier spring will be the best solution towards the problem. The shock only controls how the spring reacts, which is to not create a bouncy ride.
Yeah, there could be a combination of issues on your KLX. Depending on how much time is on your KLX, as Brewster suggested you could need a shock service. Also depending on your riding style and your outfitted rider weight, the 5.8 spring might be on the light side for your needs. I revalved my rear shock and went to a 6.0 spring with excellent results. If you need shock service, it would be a good opportunity to get it revalved at the same time. It's a fairly amazing transformation that's worth the money.
urnumberone
Dec 22, 2006 09:04 AM
JohnnyfromBama
Dec 13, 2006 11:42 AM
