$17 rear tail bag!!
Old Jun 23, 2009 | 02:33 AM
wkn4lo's Avatar
Wolfman Enduro Tank Bag. Got it at www.dualsporttouring.com.
Old Jun 23, 2009 | 05:49 AM
CBH4187's Avatar
Sorry for continuing to go off topic, but... I'm curious, did you drill holes for the control housing or did you grind down the nubs?
Old Jun 23, 2009 | 09:36 AM
wkn4lo's Avatar
Ground down the nubs.
Old Jun 23, 2009 | 09:41 AM
neilaction's Avatar
Then if they slip, as mine did, a layer or 2 of electrical tape did the job.
Old Jun 23, 2009 | 11:03 AM
vtgreen's Avatar
Moose Racing KX Hi Steel Handlebars
$19 at Motorcycle Superstore
Just a little wider than stock but I like them better. Plus work better with Moose Racing Handguards!
How much wider are they? Can you measure? I have the Moose Contour handguards and they don't fit my stock bars. Rather than go through the hassle of returning them and getting something different, for $20 I might as well just buy new bars.
BTW, I like the bag set-up!
Old Jun 23, 2009 | 11:43 AM
Sid Post's Avatar
The factory bars are pretty weak. If you ride tough off road trails, get some Protaper bars. I really like the KX High bars I installed.
Old Jun 23, 2009 | 03:51 PM
pking911's Avatar
where did you get the rack at?
Old Jun 23, 2009 | 09:26 PM
wkn4lo's Avatar
The bars are about 3/4" longer on each side. The rack is from ebay. He might be out of them now. I learned about them from these forums!
https://www.kawasakiforums.com/forum...ight=rear+rack
Old Jun 23, 2009 | 09:42 PM
pking911's Avatar
Thanks. I will check it out.
Old Jun 24, 2009 | 12:09 AM
armycopter's Avatar
+1 Pro-Taper KX High
