KF Help & Suggestion Center Need help with KF? Ask. Have a suggestion to better KF? Tell us here.
ECU codes
Old 07-30-2017, 09:41 PM
Bobbyd1968's Avatar
Default ECU codes
My 2003 kawasaki Vulcan 1500 mean streak ECU is not giving me any codes when I run the self diagnosis procedure. The FI light works as it comes on when the key is turned on and then goes out. Bike shut it's self off and will not start. HELP. It has an after market fuel manager on it as well. I smelled fuel the last few times I rode it after I shut it off. Has fuel in the oil. No pitcock valve.
Old 08-01-2017, 03:27 AM
You answered your own question. Remove the new stuff then continue your diagnostics. Fuel in the oil is a bad thing, so get this issue solved. What fuel manager are you referring to?
Welcome to KF
rd2die
05-26-2015 06:55 AM
anicentx
Ninja ZX-14
09-05-2010 12:44 AM
sledgehammer
06-02-2010 02:37 AM
dsm3383
07-10-2009 08:37 AM
brute750i
04-06-2008 01:11 PM
Quick Reply: ECU codes
