KF Help & Suggestion Center Need help with KF? Ask. Have a suggestion to better KF? Tell us here.
2005 Brute Force 750i
Old Jun 10, 2008 | 01:33 AM
mark_deb's Avatar
Default 2005 Brute Force 750i
Thanks to the response. Here's the nuts and bolts of my problem. Repair manual states to check the brake actuator which which does test bad. Problem is when I check the 4wd actuator it checks out bad too! If both are bad I should be getting a 4 second alternating indicator light and I'm only getting a two second. Two actuators going bad at the same time? No changes by disconnecting one or the other.Does it hurt anything by pulling the electric motor covers off on the actuators? If I putI a new actuator how do I know its in the proper position when I install it? Here I thought I was a pretty smart guy. This has got me wondering. Repair manual is not helping much. Any help out there would be great.
2ndhandsony
Aug 19, 2013 09:09 PM
mark_deb
Jun 10, 2008 01:42 PM
mark_deb
Jun 9, 2008 03:06 PM
mgspencer
Feb 20, 2007 06:08 PM
