Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
kfx450 fan issue
Old Dec 6, 2012 | 12:00 PM
450atvrider's Avatar
Default kfx450 fan issue
I have a 09 kfx450r and found that my fan is not working,checked a few simple things from the shop manual,however at no time/heat do I get power to the fan circuit at all.Anyone run into this ? any help appreciated
I've checked the wires going to the fan motor,fan relay(removed frt plastics)and temp sensor(behind cyl),I've checked these when at ambient temp and at upto 230 degrees when the fan should be on(with the exception of the sensor due to location when hot,don't have long enough probes on meter)but nothing in the circuit is energizing.once again any help appreciated
Old Dec 6, 2012 | 02:37 PM
Welcome to the forums. Not sure about the ATV, but on my KLX, my fan only comes on if its over 100 degrees out and I'm in first gear on a single track trail going slow.
Old Dec 7, 2012 | 11:49 AM
deej,thanks for the reply,not to sure what you mean by 100 degrees out,unless you mean air temp....but whatever....the klx and the kfx are 2 completely different aminals...thanks for trying tho...
Old Dec 9, 2012 | 02:31 AM
all fixed...time for some trails
tedphips23
Jun 22, 2009 03:17 AM
Melyza_Cheerleader
May 26, 2009 03:56 AM
Melyza_Cheerleader
May 23, 2009 05:17 PM
HKatt527
Apr 15, 2008 06:32 AM
crazyforkawi77
Mar 20, 2008 01:58 AM
