Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
I have just noticed that my Bayou pulls some what hard to the right.
Old Nov 13, 2008 | 03:58 PM
skos's Avatar
Default I have just noticed that my Bayou pulls some what hard to the right.
I have just noticed that my Bayou (1986 Bayou 300) pulls some what hard to the right.
I already check tire pressure, try adjusting and even swapped the 2 front tires.
Is there an adjustment?
Thanks, Steve
Old Nov 13, 2008 | 04:05 PM
Pulls hard when you let go of the bars? Pulls hard when you brake? Need more information. Oh and welcome to the forums if we haven't already said so.
Old Nov 13, 2008 | 05:54 PM
skos's Avatar
when I let go. I believe I have the answer, does this seem correct?
Wheel Alignment
Toe-in of Front Wheels 15 ∼ 35 mm (0.59 ∼ 1.38 in.) at 1G
Steering Centering Adjustment •Hold a straightedge [A] against the rear wheel rim on one
side at axle height.
•With the handlebar straight ahead, loosen the locknuts [A]
[B] and turn the tie-rod adjusting sleeve [C] until the front
wheel on that side is parallel to the straightedge.
NOTE
○The locknut [A] on the opposite side of the flattened area
[D] on the tie-rod has left-hand threads. Turn the wrench
clockwise for loosening.
Wheel Alignment
Toe-in Adjustment •Loosen the locknuts [A] [B] and turn the adjusting sleeves
[C] the same number of turns on both sides to achieve the
specified toe-in.
NOTE
[D] on the tie-rod has left-hand threads. Turn the locknut
NOTE
○The toe-in will be near the specified value, if the tie-rod
length [A] is 288 mm (11.3 in.) on each tie-rod.
CAUTION
Adjust the tie-rod length so that the visible thread
length [B] is even on both ends of the tie-rod. Uneven
thread length could cause tie-rod damage.
•Check the toe-in (see Toe-in Inspection). •Tighten:
Torque - Tie-rod Adjusting Sleeve Locknuts: 26 N·m (2.7
kgf·m, 20 ft·lb)
•Test ride the vehicle.
Old Nov 13, 2008 | 07:09 PM
Not sure about all that, could be, but make sure the brake isn't hanging up at all.
Old Nov 17, 2008 | 07:57 AM
whitehendrix's Avatar
definitely sounds like alignment.
if the wheels spin freely when the front is jacked up off the ground (the brakes aren't hanging up) then i would DEFINITELY check this next.
the steering whell should self center and the vehicle should track straight when the wheel is let go going forward.. an indication might be to go backwards a few times from a centered wheel.. see which way it cuts. then again, going forward, you have caster on your side. not so much going in reverse.. lol
but ya.. go thru the alignment procedured.. that is probably whats wrong..
good luck, keep us posted, and welcome to KF!!
Old Nov 23, 2008 | 09:15 PM
Will Shoe's Avatar
Sit on the left peg. Problem solved
Old Nov 23, 2008 | 11:42 PM
kx slaughter king's Avatar
lol, if its anytihng like my rancher theres a ton of tar and mud in the tripple clamp thing and it locks up in the air after bumps, randomly throwing you at trees
thats a fun game at 45-50mph on 4ft wide trails
Finger Mullet
Sep 22, 2007 01:01 AM
southernguy21
800, 800 Classic & 800 Drifter
Jun 8, 2007 04:25 PM
Marty
Dec 16, 2006 06:36 PM
shon
Aug 31, 2005 05:24 PM
shon
Aug 3, 2005 06:49 PM
