Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
bayou 300 odd noise
Old 09-15-2009, 06:42 PM
squirel022003's Avatar
Default bayou 300 odd noise
I have a 1998 bayou KLF300. The machine still runs but i went on a 200 mile trail trip and when i got home i noticed a spining noise after the atv is shut off. If i start it in neutral the noise continues after the machine is shut off and then it will stop after a few seconds ending with a small clunk. If shut off in gear the noise is not heard, I also hear a small chatter while in gear with the brake on and reving the engine. Any tips or thoughts would be much appreciated. I really do not want to bring it to a repair shop as the machine is older.
Thank you,
Old 09-17-2009, 11:04 PM
Still can not figure this one out. any help would be appreciated.
Thank you,
Old 09-17-2009, 11:32 PM
95451's Avatar
Welcome To K.F.
Sorry got nothin for ya.
I did find this tho. Good Luck
http://www.amazon.com/KAWASAKI-PRAIR.../dp/1563925222
Old 08-22-2013, 05:26 AM
Brianbbs67's Avatar
Starter staying engaged or trying to be. Bad starter or button, two possibilities
Old 08-22-2013, 05:28 AM
Brianbbs67's Avatar
Quick check is when noise is heard, disconnect starter hot lead and see if noise stops or fuse of so equipped
Old 08-22-2013, 05:29 AM
Brianbbs67's Avatar
Ps yours ain't old, I got a 87!
Old 12-05-2017, 03:11 PM
Blackout987's Avatar
Thank you,
did you ever figure out what was wrong? i know this is an ancient thread but i am having the exact same issue.
JasonFMX
03-18-2010 07:59 AM
1500bill
09-17-2009 05:41 AM
aszrael1266
09-18-2007 10:59 PM
kx slaughter king
08-28-2007 08:35 PM
incabiker
03-03-2006 03:50 PM
Quick Reply: bayou 300 odd noise
