Rear cylinder not firing, limp mode??
I have a 2016 4010, I’ve been digging into a low power issue. The fuel pump was replaced a couple years ago and for some reason I started there with my troubleshooting and replaced the filter with no change. Next I cleaned the throttle body with no change, it was then I realized that the rear cylinder wasn’t firing, I replaced the ignition coil convinced that was the issue but no change. I did find a broken wire below the front coil (blue-pink) attached to some plug bolted to the engine, at that point I was frustrated but relieved that this could possibly have been my issue all along but after fixing the break with a butt connector , but no change, does anyone have any suggestions or ideas? The broken wire is the same color as a wire going to 3 different sensors on the throttle body
_Michael
Jan 12, 2022 10:06 AM
