No high range
Old May 12, 2019 | 01:54 PM
Polaris192's Avatar
Default No high range
I just purchased a 2011 4010 trans gas and the high range does not work. Low neutral and reverse work but when I shift it to high it is in low range. Any direction before I tear into it? Thank you in advance!
Old Jun 5, 2019 | 09:54 PM
Muleman's Avatar
I know they are two different animals and don't know much about you model year but...mine is a 1997 and it had the same problem. Many thing besides this fix could be wrong but mine was nothing more than a cable adjustment. It was not engaging fully. It took two seconds to fix!
Old Jun 6, 2019 | 01:45 PM
Polaris192's Avatar
Good point. I have not taken a look at this yet but you comment does make sense. I hope that is all it is!! Thank you.
Old Jun 9, 2019 | 10:00 PM
CrashWrench4010's Avatar
Hi,
First ,,, Got a / Get a Service Manual !
Plus 1 , On the Cable ( s ) Adjustments ( On Top ) the Tranny ( With the large Arm ) Controls " Forward / Neutral / Reverse " . The Next Cable Controls ( Short Arm ) " High / Low Speed " Range .
There Two (2 ) More Cables Hooked To That tranny They Are : Most Rear Cable By the " Rear Differential Case / Rear Drive Shafts Is For The " REAR Diff . LOCK - UP " Last Cable Over By Side Case ( By The Output
Housing For the Front Drive Connects to : IS For > Two (2) / Four ( 4 ) Wheel Drive Selector Lever .
One Problem That Makes These " MULES HARD TO SHIFT IS >> If The Engine IDLE SPEED IS TOO HIGH ! The CLUTCHES NOT DISENGAGING Completely !!!!!
If You Have !! Any Play / Wear In The Shifter , Cables and Rod Ends ,,, These Items Need To Be Repaired First Before Any Adjustment Can Be Made !!! .
Check For wear / Play in The Gear Selector/ Shift Lever In The Dashboard ( It Has plastic Bushings In The Lever )
To Adjust , Start With The tranny In Neutral , In Two (2 ) Wheel Drive . Differential Lock . Out / OFF . Engine ,, OFF
You Will need to Make Two ( 2 ) " Shim / Spacers " pieces of ( Metal ) About Two ( 2 ) inches Wide By Three ( 3 ) Inches Long . Thickness About Sixty Thousands ( . 060 ) Of a Inch , Two ( 2 ) Small Pair of Vise Grip / Locking Pliers ,
One ( 1 ) Rubber / Bungie Tie down Strap .
( Really Need A Service Manual ! )
With The Gear Shifter in The " Neutral Position ( That's Down and Left In The Slots ) Place One " Shim / Spacer " in the Vertical Slot ( Left of the shift Lever Rod Coming Out Of Dashboard ) . Lock It In Place With A Locking Plier .
Next Place The Second " Shim / Spacer " In the Horizontal Slot ( Under The Shift lever Rod ) . Lock it In Place . Take Your Rubber / Bungie Tie Strap , Hook it to the Shifter Lever And To something ( the seat Bracket ? ) To
Keep the Shift Lever From Moving .
OK , Now Back on the Transmission ,, LOOSEN Both Cable's Lock Nuts , Check The tranny Is / Should Be IN Neutral ( Large lever ) Now Tighten The Two ( 2 ) Lock Nuts (( !! With Out Moving That Lever !! Tricky ))
Next The " High / Low Speed Range " Lever . ( With Gear Shifter Locked ? The Range lever Is " Spring Loaded > So The Will Be In High Range . Again Tighten the Lock Nuts On The Cable ( Without Moving The Lever !! ) .
That's It .
Remove the Tie strap , Remove the Pliers And " SHIMS " Ok??? Set the Park Brake ? Start Engine . Gently Move Shift Lever Into " Forward " It Should Move Into Gear WITHOUT Grinding !! Try Reverse ? Try LOW RANGE ?
!!! IF IT GRINDS While Trying ??? Shut DOWN !!!! Recheck Your Work ? Recheck Shifter Parts ? After All The Above DOSE NOT WORK ??? YOU Have A Tranny Broke ,, Sorry ;(
IT Takes Longer To Read this , Than Doing The Work .
Hope This Helps ? ( Got Service Manual )
Mark
Old Jun 10, 2019 | 02:51 PM
Polaris192's Avatar
Awesome for the details. And yes good point I will pickup a service manual!! Thank you again!
Old Jul 11, 2024 | 03:39 AM
Ferlin's Avatar
How did you adjust cable
Ti3m
Mar 5, 2019 04:16 AM
Gummikuh
Aug 15, 2013 09:23 PM
tylercq
Jan 20, 2009 04:23 AM
kidritalin
Oct 29, 2007 02:59 PM
walight01
Oct 9, 2006 05:34 PM
