Neutral switch location
Can someone tell me where the neutral switch is on a 2006 Mule 3010? I looked through my tech manual and i see a schematic but not a picture of the exact location.
Two days ago after shutting the mule off it would not start--nothing happened when the key was turned. I pulled it back to the house, about 1/4 mile, tried it and it started immediately and has had no problems until today. I went to put it in neutral to shut it down and it died before I touched the key. Now I'm back to a dead ignition. I'm guessing the neutral switch. But if you have any other ideas let me know. Thanks
1/26/22 Update.---Negative battery cable was loose. Tightened that and everything works. Always check the simple stuff first!!
The problem returned, or at least a similiar problem. All the cables are good and tight and the battery checks out. However all I get is a "click" from the solenoid. I put a new starter on and still have the same problem. However, if i jump straight from the battery to the solenoid it starts every time. I'm thinking that maybe the neutral safety switch is going bad. In any case I want to check it before installing an ignition by-pass switch. Can someone tell me the location of the neutrtal safety switch on a 2007 mule 3010?
Thanks
Thanks
