Mule 4010 - Turn Engine by Hand
Old Sep 24, 2018 | 04:43 PM
cbogle123's Avatar
Default Mule 4010 - Turn Engine by Hand
I have a 2018 Mule 4010 and I am trying to figure out the easiest way to turn the engine over by hand so that I may find TDC to do the valve inspection/adjustment. I have the factory service manual but do not wish to follow it by disassembling the stator cover to use the timing marks as a reference. I prefer just to pull the plugs and the valve covers, and use a screwdriver in the cylinder to get as close as necessary to TDC to do the valve check. I'm looking for a shortcut...I know how to find TDC without the timing marks, I know how to do a valve check/adjustment. I just can't figure out if there is an easier way to turn the engine over by hand without the disassembly called for in the service manual. Thanks,
Old Sep 25, 2018 | 07:31 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
or this one is even more focused:
https://www.kawieriders.com/forum/
Paul Leischner
Jan 14, 2019 08:32 PM
Yami Oquendo
Jul 9, 2018 03:27 AM
Green Truck
Apr 24, 2018 06:00 PM
Tomstoys
Feb 13, 2018 12:36 AM
njordan
Jan 25, 2018 03:40 PM
