HELP! 2005 3010 mule fuel pump issue
Hello, I have a 2005 3010 mule. I have been fighting a issue for awhile now and looking for insight.
It started with my mule stopped running. After looking it over I found out my fuel pump was not pumping.
I replaced the fuel pump with a new one and charged the battery on the mule because it was low from cranking trying to get it to run. With the new fuel pump and battery charged the mule ran fine. The mule ran fine for a few days then did the same thing again and died! The fuel pump will not pump! If I turn the ignition key to on, I hear the fuel pump click once. I can keep doing this till there is fuel in the filter then start it and will run good till filter runs dry. When the mule is running on the full filter, I never hear or see the fuel run at all.
i know there is an ignitor that tells the fuel pump when to pump, I have also read about a relay. I don't know which way to turn. Thanks!
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
or this one is even more focused:
https://www.kawieriders.com/forum/
