2017 mule Pro DXT
Old Apr 18, 2018 | 03:16 AM
Landry's Motosports's Avatar
Default 2017 mule Pro DXT
Can anyone help me with a fuel delivery issue on a 2017 Mule Pro DXT diesel. Bike starts and runs fine for about 10 minutes then starts to die and ultimately kill. What is happening is the fuel pump quits pumping after it warms up. What I have troubleshooted so far shows the pump is good. The 2 relays are also good I believe. After it warms up the fuel pump will only prime when the ignition key is turned on. Once i start the engine the pump does nothing unless I let it sit for a while. Then it will do the same thing over again. Does anyone have any direction to point me in. This is the first mule I’ve had to repair and need a little help if anyone has any knowledge of these things.
thanks!
Old Apr 18, 2018 | 02:12 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
Old Apr 18, 2018 | 03:03 PM
Ok thanks
Old Jun 14, 2025 | 01:54 AM
Cleming's Avatar
Did you ever figure out the fuel pump issue having same problem.
blackswamp
May 10, 2023 11:05 PM
Bob Johnson
Apr 28, 2021 11:19 AM
njordan
Jan 2, 2018 07:49 AM
thetucks
Oct 24, 2015 12:32 AM
asand211
Aug 30, 2015 10:08 PM
