Front drive CV joint
Old Jul 21, 2018 | 09:22 PM
donwnby's Avatar
Default Front drive CV joint
1990 or 91 Mule 4x4
The boots on the front CV joint have to be replaced.
I pulled an axle and removed the old boot. It appears the CV joint cannot be torn down. There are no snap rings or other means of getting it apart. It appears the snap ring in inside the unit.
The manual tells me that if the boot craps out replace the axle.
Easy for them to say.
I have new boots.
Suggestions welcome.
Thanks
Old Jul 22, 2018 | 08:48 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
or this one is even more focused:
https://www.kawieriders.com/forum/
Old Oct 31, 2018 | 01:26 PM
Ed ke6bnl's Avatar
I just got a 3010 and the front boots where bad. I did them, only one cv comes apart I believe the out side and you remove it and take off the inside on off and replace and put the outside back on. was not hard but time consuming.
deerefan
Feb 21, 2019 03:47 PM
Zackmichels
Feb 21, 2019 03:46 PM
Braddodd
Oct 5, 2018 09:38 PM
Icestationzebra
Aug 8, 2018 11:09 PM
Ericka Aguayo
Jan 25, 2018 03:49 PM
