Emergency Brake
Old Mar 2, 2007 | 08:35 AM
cowboy's Avatar
Default Emergency Brake
The emergency brake on my Mule 610 4x4 fails to engage. As I pull the lever no "clicks" are heard. If I hold the e-brake lever as if it was engaged, the vehicle is held in place. It appears that the screws to the wires are in-place. The brake release button on the end of the lever does not move. Does anyone have a suggested fix? Thanks.
Old Sep 10, 2007 | 12:18 AM
KLX450R's Avatar
Default RE: Emergency Brake
If you pull the left plastic panel off you can gain access to the handle. I would guess that you have a release mechanism sticking and needs a little lube. The panel can be removed with a flat screw driver to remove the plastic rivets and a phillips screw driver to remove the screws in the rear and bottom of it. If all else fails, and the lubing doesn't cure the problem, you had to remove the panel to remove the handle to replace it anyway.
Hope this helps,
Jody
Old Mar 5, 2021 | 11:47 PM
scubawerx's Avatar
I need this part for each side of my '04 Mule 550. Any help is appreciated.
scubawerx
Mar 5, 2021 11:45 PM
durielk
Oct 9, 2013 03:59 AM
Pepe72
Sep 17, 2010 01:45 PM
sg1982
Apr 20, 2008 08:48 AM
