2011 4010 diesel clutch slipping?
Old Oct 13, 2018 | 09:10 PM
Rudeag's Avatar
Default 2011 4010 diesel clutch slipping?
Mule loses speed on slight incline. Sometimes belt squeals on take off. Is clutch adjustable? Belt bad?
Old Oct 14, 2018 | 03:00 AM
bpmule's Avatar
The drive belt deflection can be measured.
If the belt deflection is not within the specified range, adjust
the deflection by adding or removing spacers on the fixed sheave of the driven pulley. When adjusting the deflection, less is better than more. Less deflection will maintain better performance for more time as the belt width decreases by normal wear, which causes the deflection to increase with usage. You would naturally inspect the drive belt at the same time.
goldstar
Jun 9, 2019 05:16 PM
rras1
Oct 29, 2012 08:40 PM
marcusknight23
Jun 24, 2011 03:37 AM
sambeaux
Jun 22, 2009 09:41 PM
Jesus Hates YouSmile
Feb 25, 2008 01:29 AM
