2008 kaf620 mule, 3010 trans 4x4 starting issues
Old 06-01-2015, 04:55 PM
Shadygrady's Avatar
Default 2008 kaf620 mule, 3010 trans 4x4 starting issues
Hello
Newbie here. I recently purchased a 2008 mule 620 3010, Trans 4x4, pretty good shape, I have been refurbishing same for use in New Mexico hunting area. Runs great, I recently ran out of gas like a dummy and now the problems have started, I cannot the Mule started, turns starts and dies, seems like engine is not getting fuel, fuel pump? I also replace the spark plug still same issues.
Thank you for any ides or help you may provide.
Old 06-04-2015, 04:14 PM
Shadygrady's Avatar
Ok so 120 views but no suggestions not even one....... thanks
Old 10-09-2015, 12:48 AM
CrashWrench4010's Avatar
Hi ,
If It is a Gas Engine ? Change the fuel filter , Check the Fuel Pump , Need to Clean the Carburetor .
If it is a Diesel Engine ?? Change the Fuel Filter , Bleed the Air out the Fuel Filter Housing ,
On Diesel's ,, Need to check the glow plugs / Engine Preheat System ...
studebaker53
12-22-2022 01:32 AM
Uyless1
06-09-2019 04:25 PM
chromedome
02-23-2017 01:38 AM
Chetos
10-09-2015 01:12 AM
Quick Reply: 2008 kaf620 mule, 3010 trans 4x4 starting issues
