2008 610 only runs on ether
Old Jan 8, 2023 | 08:52 PM
Srice's Avatar
Default 2008 610 only runs on ether
Last week my mule died while driving and wouldn’t restart. Since, I have changed fuel filter, fuel pump (didn’t really need) and carburetor and for kicks changed the spark plug.
I can get it to run on ether but it will not run on its own. Any suggestions?
Old Jan 30, 2023 | 07:08 PM
cobracosta's Avatar
Default Carb Issue?
I'm interested in response as well, I have new Carb new fuel pump and filter. when I pour gas in carb it will turn over and run for about 4 seconds then sputter and die. What other then carb would cause this? maybe vacuum line to the fuel pump.
Old Jan 31, 2023 | 09:03 PM
Srice's Avatar
FOLLOW UP-- In my case it was water in the fuel tank. After draining the tank, I guesstimated about 20% of the full gas tank was water. We only have one gas station in my town so am certain they were the culprit! Good luck to others with similar issues
Old Feb 6, 2023 | 07:16 PM
cobracosta's Avatar
I rerouted my fuel using a gas can as I thought I had alot of junk in the gas tank. But I'm still having issues. I am soaking the carbs for 2 days now hopefully I'll put them back together and itll be fine. But I'm thinking its not the carb.
blackswamp
May 10, 2023 11:05 PM
alexander
Aug 31, 2021 09:52 PM
Adam$77
Oct 20, 2019 10:01 PM
brad6882
Mar 31, 2018 05:30 PM
Shadygrady
Oct 9, 2015 12:48 AM
