2006 3010 gas: new owner: A few Qs: Winch
2006 Mule 3010 Trans 4x4. I think that means it can be 2 or 4 seater? Mine has 4 seats but I will use as 2 seater: I like the bigger box. She's a bit rough but only 374 hours. Just ordered a set of 25x11-10 tires as I read these will fit with no lift. Woulda been nice to find some wheel options to bling it a bit, but not much in the 10". Maybe coulda went with a 12" wheel with 4 x 137 bolt pattern but was worried tires might rub.
Q: Manual says 10 psi Front and 24 PSI rear. Front makes sense but 24 PSI seems high for rear. What you guys running?
Q: Roof...i ordered the fabric one. The hard ones seem to be 4 piece or 2 piece plastic and are pricey. Any good, 1 piece solid options? Was also thinking some sort of chunk of plexiglass and just u-bolt it on. I'll see how the fabric roof works. You get wet in rain period, so just trying to keep a little off the inside.
Q. WINCH... will a winch fit in behind front bumper and anything critical to know for install? I already had a Champion 4K winch so will use that.
Ordered 20" LED light bars for front and rear. Really thinking about adding power steering. Also gonna put on some mirrors. It is farm use so no need to go too crazy I figure. I've owned Rhinos and Wolverines in the past but they are loud and not the perfect farm machine...great on trails but I need a worker more than a toy.
Would probably be a good idea to change all fluids. Original owner used it at a lodge to run guests up and down steep paved area. Tires are bald. I don't think its seen much dust or dirt, air filter was clean and I think all he did was change oil. Thinking I'll dump diff oils. Rear looks like regular 90SAE gear oil, front says 85-140 friction modifier gear oil. Anything special I should know about front gear oil?
It seems to run really solid. Will probably be a lot of stuff I end up asking. Thnx for any intel.
Jm3010
Oct 18, 2016 01:09 AM
