Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
jet ski kawasaki 750 xi 1993
Old Nov 19, 2011 | 02:44 AM
juan romero's Avatar
Default jet ski kawasaki 750 xi 1993
how to prime the fuel lines, we just repair the motor and cleaned carburator, do not have fuel in the lines.
Last edited by juan romero; Nov 27, 2011 at 12:42 AM. Reason: need help for my new jet ski
Old Nov 27, 2011 | 12:43 AM
does any one have inside pictures of your kawasaki jet ski 1993 750 xi ?
Old Dec 20, 2011 | 08:35 PM
OldGuy's Avatar
I don't own a '93 750 XI, but all the 750's of the '90's are pretty much the same in most areas. To prime the carbs after rebuild, just pull the "Return" line that takes excess fuel back to the tank. Then turn on the main fuel valve, and wait for gravity to carry fuel thru the carbs and start dripping out the return line fitting. If you don't mind getting intimate with the fuel fill hose, you can help it along by putting your mouth to the fill hose, and blowing into the tank. An alternative method is to prime the carb by squirting a small amount of pre-mix fuel down the carb, and start the engine. After running a few bursts on the pre-mix, the carbs should be full, and the engine stays running.
Old Dec 21, 2011 | 12:04 AM
BleednGreen68's Avatar
Yea make sure you have the fuel lines routed right. Priming the carbs with mixed fuel is better. Gettin gas in your mouth sucks! haha
Old May 17, 2012 | 03:05 PM
beachvol's Avatar
Hello. My name is Steve. I have been away from forum for a long time. I have the same problem. My 92 750 SS was in storage for 7 years. I had carb rebuilt. It will start with prime but will not run. I tried the return and blew in tank as you suggested to no success. You sound like you know what you are talking about. Any further suggestions.
Thanks
Old May 20, 2012 | 03:53 AM
Could be bad fuel pump too.
Old May 20, 2012 | 12:46 PM
beachvol's Avatar
I spoke with the local Kaw dealer and he was very helpful. Seem after long storage the fuel decomposes. The return line was plugged. I removed the pick up from the top of the tank and found huge deposit around the return opening. Removed and ski runs great.
ready_2_retire@yahoo.com
Aug 11, 2015 01:48 AM
jprickett
Oct 4, 2007 01:44 AM
danriley50
May 13, 2007 05:35 PM
drwieg
May 29, 2006 09:45 AM
